Machine number KJL00898
Engine number THX14748
6700 hrs.
For the past few months this dozer will throw a fit now and then and it would cough, blow white smoke, maybe die, maybe just almost die. But they'd shut it off, let it sit for a few minutes and it'd be fine. Might run for another 40 hours before it did it again.
Recently it's gotten worse and the fits were becoming more common so they decided to address it. Yesterday when I started on it the machine was running slightly rough but not really missing. It was definitely low on power though. No codes, all vitals being watched through Cat ET checked out fine. I had my suspicions of #4 injector but couldn't prove to myself it was the problem.
I returned today to sort it out and it had to crank for 15 seconds or so to start. It ran for about 10 minutes then just died and now won't restart.
Actuation pressure while cranking is only showing 530 psi and I believe minimum is 800 to start.
Engine oil pressure is 35 psi and fuel pressure is 38 psi - both while cranking.
I confirmed all these pressures with manual gauges.
Is there anything else I should check before replacing the HEUI pump and all 6 injectors? It's at 6700 hrs which I've found to be close to the magic number for these C9's needing both.
Any input is appreciated.
6700 hrs.
