overworked
I would keep your d6 and buy the d8t with the price of the 7e it's not worth it, just a over priced d6. D7e pushes liked6r and cost like a d8
At the current time, the money spent on electrical problems is neck and neck with the cost of the undercarriage. I would have never expected that.
Electronics will only get more involved as we go. Its cheaper to put a wire from point a to b with controls then an actual linkage as of old. Understanding the electrical systems woill be key today on. Understanding PWM systems is a plus , the other , different systems use different voltages which sets another problem the echo effect. One system wigs out due to another irregular voltage , these can be lower than .01 . This floors your old school mechanic , because its doing one thing but the computer points else where. Old schools wants to go by his gut feeling. 953C went to neutral with brake locked while moving . Not a trans problem , temp sender was faulty telling the ecm to park it. And it parks without warning. New temp sender , ready to roll . 150$ part , trip to Lex and back up and running. The dealer would bill out around 1500 or more for this repair. If it were my choice , fuel would be the deciding factor. The 8T is solid , the 7E , well look at locomotive technology , underground mining technology , even cars . Electric drive its self is not specifically new , to a track tractor yep. But what do I know , I run a D39E-1 Komatsu .
If u are having electrical problems that equate to the value of the track gear get rid of your electrical team fast that is your true liability.
to jdofmemi..
how else can cat get you to trade more often?
Yes, but they may not like the trade in my case. It has really soured me on new iron, and buying good used models before the electronic infestation and getting quality rebuild work done seems to me to be a far better deal than new.
You are right Old dirt , I would advise him not too over spend , things can go sour .I live in sw iowa and there is very little conservation work left undone here. Most farmers all have their own yellow toys now and don't hire much. You are very lucky. Best of luck, either tractor will do well.
