Hello. I purchased this excavator in February. It has 4800 hours on it. I noticed that that the O-ring was leaking at the hydraulic oil cooler. I fixed the leak but found that the oil had clogged the oil cooler, radiator, and cac. I removed all of them and sent them to a radiator shop to be cleaned. While I had them out I went ahead and changed the water pump, thermostat, idler, tensioner and belt. When running it i found that the gauge wasn't reading properly and that it was running hotter than it read. I found that the temp sensor was unhooked at the thermostat housing. Once i hooked it back up after running it for 30 minutes the temp will start over heating this is with the outside temp being 90 degrees f. I checked the radiator with a temp gun it it shows to be cooling it off roughly 15 degrees. That's when I noticed that the hydraulic oil will be around 180 degrees f coming into the cooler and it will only be a couple degrees different coming out of it. I have ordered the test and operations manual off of eBay but I'm unsure where to start just yet. Does this seem like the hydraulic temp is what's causing the engine to run hot? On a side note I know the hydraulic fluid is good as i just changed it with the Hitachi oil and filters roughly 100 hours ago. I also had the center joint rebuilt with Deere seals.
