shane mercer
Hey guys I have a 2008 Deere 160D excavator. Difficulty starting at times, sometimes it will surge at idle, then when under load it smokes bad and has no power. Sometimes it runs fine. It is throwing code 627-1, but only when it is acting up. When the machine is running fine it does not have any active codes. Any help would be greatly appreciated as to what to check next. I've replaced one injector, and also the fuel suction control actuator. I have the other 3 injectors on order, but im not sure this will fix the problem as sometimes the machine works fine and sometimes it does not.
Thank you
Shane
Thank you
Shane
