Deere 544K service manuals needed/flywheel repair
Evening Digger
Georgia
I have a 544K that has some teeth missing from the flywheel ring gear. Does anyone have a manual (or better yet-experience?) that covers this? Need to know how big of a job it is. TIA
tool_king
new jersey
road mechanic owner
Just the nature of it the motor will have to be pulled to replace it .I have the repair manuals what is your email address ?
partsandservice
Georgia
Not to contradict, because in my experience Tool king's knowledge is vast. The 544k transmission is connected to the engine with a drive shaft and dampener. The hydraulic tank can be removed to gain access to the drive shaft. Flywheel can then be removed from the engine .
  • Like
Reactions: DB2
tool_king
new jersey
road mechanic owner
No big deal I was out with my son's and was trying to do it from memory with out the book or machine in front of me as they were asking questions about stuff we fixing together .
adamr
Hi all
we have a similar issue with a 544K, do you have to take the engine out or the transmission out. does anyone have a repair manual for this machine
Thank you
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF adamr;)!
Either remove the hydraulic tank for access (which involves partial tipping of the cab) or remove the engine. Transmission does not get removed for that repair.
Evening Digger
Georgia
It turns out our problem wasn’t the flywheel but the starter. May double check that if it seems the flywheel is missing teeth. Starter is much easier to access:)
