Diesel has lubricating properties, otherwise your fuel injection pump would seize up.
2 gallons of diesel in 15 gallons is merely going to thin the oil a little, so you will find the hydraulics work faster when cold - but with the thinned oil, you're likely to see more hydraulic leaks.
