Georgia Iron
- Joined
- May 6, 2012
- Messages
- 887
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
So I have a Case sv340 skid steer and the front door got hit by a hidden piece of rebar. Shattered the glass door and slightly bent the frame work. After checking my options, Case wanted $4000.00 + for a demo door unit or $400 or so for a new piece of glass. I went after market and ordered a 1/2" thick custom lexan door glass replacement for $800.00. I spent several hours cleaning off gasket and broken glass. I then installed it in my existing metal frame using the 3m product.
After a few weeks of shaking around the lexan pulled loose from the frame work and I decided I would drill some holes in it and hold it to the frame with 20 1/4 bolts 3 hours later i had it drilled and everything nice and tight and left at dark. Next day had a 100* day, while i was away at work. The lexan swelled and broke at almost every hole. I did not have any rubber washers installed and in my mind I thought having it nice and tight was the way to go. Leaving it a little loose would have given it room to move.
Let my mistake help you in your foresty door installation.
