crane operator
1998 Detroit 60 series. Thought I had fuel line issues/ sucking air. Had one fuel line show leakage when using air pressure to test it. Went ahead and replaced all lines, drained fuel tanks and new filters. Had a little algae in one filter. Treated fuel and refilled tanks.
Truck idled fine at shop. Went for a test drive bobtail, drove for 15 minutes no problems, ran great.
Hooked onto lowboy trailer, total driving time now of 20 minutes or so, less than a mile from my shop, dies in the middle of the road. Acts like no fuel. One fuel filter when pulled, shows not completely full of fuel. Blew lines out on side of road with air (thinking maybe algae plugged in splitter block, no luck) took the fuel line off splitter block and put in a fuel container, still no running.
Jim (my mechanic guy) thinks the ecm is bad- poured cold water on the ecm, and the truck takes off running. I got maybe another mile down the road and put in a parking lot before it died again.
I had a little problem a while back with the throttle pedal, jakes would pop on and off, but if I would fiddle with the throttle pedal, they would work, so I put a new position sensor on it a week or so ago.
Throws no codes when it dies. It runs like a top when you first start running. The first time it did this I was maybe 20 minutes into a equipment move, and made it to the site, then limped home (runs, misses and kind of dies, runs a little more, etc.)
Both times I've tried it since working on it, it seems like it runs great until 10-20 minutes in, then dies, and you can't get it going again.
I've once had a algae issue, it would plug up on a one way flow valve gradually, then kill the motor for lack of fuel. Leave it sit, then it would fire right up again, run 15 minutes then starve. That's why I tried the bucket, but it didn't really take off and run until we poured the cool water on the ecm. Then it only made it another 1/2 mile or so before dying again, so I'm not convinced that its not fuel.
So in order of issues:
1: Jakes popping on and off- would fiddle with throttle pedal, then they worked, replaced throttle position sensor- seemed to fix that.
2: Leave shop loaded- 20 minutes into drive, truck falls off, then takes off, several times, manage to make it to site, unload and limp home with it occasionally dying.
3: remove fuel lines, one shows breaking down, change them all. Both fuel filters dark, and a little algae in one. New filters, all new fuel lines, test runs at shop fine
4:Bobtail runs fine, hook on lowboy, 20 minutes total run time, falls off totally. You can crank it over and it will kind of miss and die, sputter along, totally die, etc.
ECM? Still fuel issues? something totally different. It runs like a freight train when I first took off tonight, seems like heat is getting to the ecm, or I'm sucking up crud/ algae and have plugged up somewhere.
Where's the old little symbol with the guy banging his head against the brick wall?
