workshoprat92
Got a Detroit ddec2. We did an engine swap as old engine busted a piston. Using original ecm. Anyhow got it in the truck and togeter enough to fill with coolant. Started and let run for several minutes. Was running great with no issues. Activated the jake a few times and even tested cruise control switch function. All checked good. Was setting there idling and it slowly developed a misfire. Got out and noticed white smoke at exsaust. It seems to have misfire at all rpm and same with smoke. Almost has a small pop with it like a jake is slightly activated. Hard to tell if its a pop or just due to misfire. Do have a check engine light. Havent had a chance to pull codes though. Do have the fuel temp sensor unhooked and the low coolant probe unhooked. I could see those causing a engine shutdown condition which it does not do but i casnt see that causing a misfure with smoke. Also let it set for a while and it still does same thing. Last time I started it, it had a hard time starting.
My thoughts on possible causes.
Cps, srs or possibly a jake solenoid leaking or sticking. Any thoughts on where to start? Will try to pull codes and valve cover today.
