danielm
I found 15 gallons of milky hyd fluid in my backhoe. Changed the filters and fluid but I suspect the hoses and cylinders will hold a fair amount that I cannot get out. My plan is to run it and change the fluid again.
I hate to waste 30 gallons of hydraulic fluid if there's a way to dry it.
Hydralic fluid seems to hold water in suspension. It does not settle out like in other oils.
Can anyone suggest a way I might be able to dewater this oil? Can I put it in a vacuum chanber and boil the moisture off ?
Ideas?
Ideas?
