oceanobob
Have a diesel rammer from wacker, a version DS72y that is way past the parts availability days.
Any idea why it will start nicely with one pull and run for a bit with a small breath of starting fluid, but seems once the material is start fluid is burned away, it slows, and then stalls out. Maybe a five or ten second run time.
We removed the tank, checked for fuel flow (which seems kinda small but then again how much fuel does a small one lunger require?), no 'ocean aroma' in the fuel, no black residue etc etc, removed and checked filter it has no sign of clog or backresistance, refilled with new fuel, checked for prime on the injector was ok....and after all that: same as it was.
Exhaust smoke a little black then white then it stalls. Dont want to put too much of the start aid as we dont want it to kick the rod!
And it isnt too cold - it was around 55F yesterday.
