69zfarmer
I just bought a TL 140 with a cab and a/c. When i change attachments i can't see the quick attach plate on the front. The step to get in the cab is right in the line of vision.
I have a wiring diagram and it shows a compressor and a condensor fan relay. Where are they located? It also says it has a ambient temp. switch to keep a/c off under 38 degrees. I dont see it in the wiring diagram. If it is there where would it be located?
