Like these https://www.brokentractor.com/p/john-deere-dozer-brush-screen-set-pv680-pv680/What do you mean by "window screens"?
All I see machine windows have is glass, no screens.
My main point is....Do you have paid employees running the machine ?Thanks gents. Oh this is a business machine. No hobby about it. The steel mesh and the strapping used in the frame costs about fifty bucks. I just bought them, thinking about making my own. The really nice ones sold commercially are beautifully done, with drilled holes for the individual wires. I don’t see the real practical advantage to that on the side screens. Front, rear, yes. Thank you guys for the input, much appreciated
DiggerDoug, only contractors, not employees. If they don’t have their own machine, then they rent ours at a discounted rate. Overall I think the ROPS is the only regulated part of field safety here. Adding additional safety features can’t hurt with the bureaucrats.
Land, timber, oil, gas and mineral rights. Small business, kept small on purpose because I enjoy hunting, fishing, trapping and my wife is hot.What type of business are you in?
Again good point. I think the screen sets come with pole for each side. I just can’t spend the money on something that looks like we can fabricate it in an hour.you are very welcome. If you go into the job knowing you want to preserve that ROPS entire, then it is easy to do. You can even put some support up from the chassis of the machine, rather than hang it all on those holes. The less it loosens up and rattles, the better.
I made these with material I had laying around. If I had enough of the expanded metal I'd have used that for all but didn't. Even so the vertical pickets work way better than nothing. I'm absolutely sure though that the holes I drilled so the panels are removable make the ROPs non-certifiable any more. I didn't care though cause a D31 isn't gonna be in a mine or construction site....Anyone here made your own DIY window screens for your dozer? If yes, how did they work out, was it harder than it looks (does not look that hard).
Drive-through window on the one side, prison on the other! I like this. The screens are fabricated to fit into pre drilled holes and held in place with stock posts that also attach at pre drilled holes. But like you say, if you aren’t running it in some heavily regulated environment, it should be fine. It would work for usI made these with material I had laying around. If I had enough of the expanded metal I'd have used that for all but didn't. Even so the vertical pickets work way better than nothing. I'm absolutely sure though that the holes I drilled so the panels are removable make the ROPs non-certifiable any more. I didn't care though cause a D31 isn't gonna be in a mine or construction site....
I would definitely do it again although I couldn't do it by myself anymore, my shoulders are destroyedView attachment 306695
I like the rock screen better than the pretty flimsy screen material I bought.I used rock screen, and think it was 1/2 thick bar don't remember the width 3 inch or so.
Welded brackets on the ROPS just like the dealer would.
Made the window frame from the bar, and welded the screen to it. Turned out great.
