Trapper
Hello,
I am looking at a 1990 Case 550 LT and a JD 650G. Both of these have about 4300 hours on them. The 550 is described as follows; undercarriage - 16" pads pins/bushings,sprockets 80% good bottom rollers & front idlers powershift trans, pedal steer 4 post ROPS w/sweeps. The JD undercarriage is in about the same condition. The Case is priced at 19,000 and the 95 JD at 26,000. The JD was a one owner dozer and used on a farm I believe. I do not have much history on the Case. I will be using the dozer to clean up about 15 acres around the house and will use it to do clean up on some cutover land. It will also be used to do brush and light duty clean up at a couple of other 30to 80 acre tracts. Any input about these two dozers and brands would be greatly appreciated.
Best regards,
Best regards,
