Drainage Question - Tile Vs. Ditch / Swale
Beckbenj
Ohio
Hi All,
I'm looking into some drainage issues I'm having at my property. There are a few holes where water is bubbling up during a heavy rain and has washed soil along with it, so I'm trying to make a plan on how to address the repairs. Option 1 would be to fix the existing tile (clay and plastic, depends on location). Option 2 would be to make an open ditch or swale. Option 2 is appealing because there are at least 5 to 6 areas of tile which have collapsed and I believe the existing 6" tile is undersized for the water that it is collecting from my property and receiving from upstream neighbors. The tile invert is roughly 2 feet deep and maintains that depth along the run from east to west as the property naturally slopes toward the creek.
I sketched out the rough topography and existing clay/plastic tile (red) and the creek which I assume it feeds into on the west side of the property (blue). For a point of reference, the length of the red line is roughly 500 feet.
My question is whether there are any significant downsides to the ditch / swale option that I'm not considering. There would be a fair amount of dirt to move but the existing tile is in bad shape and most of it likely needs to be replaced anyhow (condition and possibly undersized).
cosmaar1
Ohio
Double check you aren’t going to screw your neighbors. Based on the picture it doesn’t seem like it as it looks to be natural runoff, however once they see a machine problems will “appear” with them as they did with me a few years ago.
KSSS
excavation
I would redo the drain tile, sized larger for the correct anticipated flow. As short of a run as it is you could run one near your existing tile and run another section at the 995 grade. I think running a swale in that situation just looks bad, and as stated you will have to maintain it. I would prefer not to see it....of course that is subjective.
I think the swale idea is a lot easier and if you put some good stone in it, it’s just mowing the lawn as long as there is not water in it.
Myself, I’d rather look at a nice snake than deal with pipe and cleaning.
Beckbenj
Ohio
From what I know only one neighbor ties into the drain for his septic and sump pump. He had mentioned his septic outflow backing up occasionally, and that it may tie into the line I’m looking at repairing. I had mentioned to him is collapsed it is collapsed in a few areas and I was looking to fix it in the future. If I let him know what my plans are and when I plan to work on the line, I don’t think there will be much of a problem from him.
On top of that, replacing sections of the line can only make it better I would think.
Beckbenj
Ohio
That’s why the swale option was interesting to me, but the cost of rock might be substantially more than pipe.
Beckbenj
Ohio
Septic tied into tile line? Might have been legal back when, but wouldn't be here today.
Why rock? You have so little slope grass would be fine. Your problem is not enough slope.
It’s legal around here. I just had a septic installed two years ago and it was approved for on-lot discharge. My septic discharges into the same tile run after treatment (primarily UV).
Rock for looks more than anything, not erosion control. But you’re right, grass could be another option.
I just meant rock for a firm bottom to the swale and possibly side’s depending on cut.
You don’t want a mud hole if you’re growing grass.
jonno634
Garfield, WA
Farmer
Hi All,
Water bubbling up, when you have clay or cement tile, COULD just be that the outlet is plugged or partially plugged. Are you sure it’s actually broken? Some old field tile made sink holes, turned out the water backed up, and came to the surface, as it slowly drained back down, it took the dirt and left a hole. Solution was to clean the outlet. Just a thought.
Beckbenj
Ohio
That’s what I was thinking at first, a blocked outlet. After probing around with a shovel I’m 100% certain the tile is broke in a few places where it bubbles up.
My septic and sump pump tie in to the main tile, which is downstream from the broken clay section. There seems to be no issue during heavy rain. I’ve never seen it back up, even in a storm producing 4” in 2-3 hours.
The other issue I’m having is I have no idea where the outlet is. The best way that I can think of is taking a probe and finding the tile every 10-15 ft.
If it is broken somewhere, dig it up and see if you can put a fish tape up it. You need to go the right direction on jointed tile so you get by the joints.
If that works, then get a copper single strand wire and put a signal in it and locate that signal.
I have the professional gear at work to use, but I think it would work with something like this.
https://www.amazon.com/F02-Underground-Locator-Tracker-Earphone/dp/B01GDZLZOU/ref=sr_1_1_sspa?dib=eyJ2IjoiMSJ9.WRm0iRobaqJUvRpxY8xPO9KDH9j6z4qAvWcKbtc_Sz63QjPOuL5SnntoA9Yn1yEcdLKeFt8qEZirNv9FIr3oanJL20eBN3-5Tc4BZkjzsZw7b26kYyifxUU9w4nPhrOiy9-bIq8rKmJpd4tkq9PJCUoYx61XpF2_ky5t-qQ0NYBotHgRozhMMNsq1VVlsP86lehufP0wN2EpNuM-FW_ijTDarPTPfG6XQPUG9leffh8.egGInWclDbsgAnrhwjJEc4g7INYSEYIEsf702LybBLg&dib_tag=se&keywords=underground+wire+tracer&qid=1710604859&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Be sure to tape off the end of the wire so it is not grounded to the fish tape or anything, then it will carry a signal.
Once you get started then it will get easier to extrapolate the run. Put in tall fence posts right over it so you can sight down them, and leave them there forever.
You can then say it is not worth fixing or you will just locate and fix it as you go.
KSSS
excavation
To Skyking1's point, you can also call a septic tank pumper, or some plumbers, they typically have a cable camera that has a locator on it. Here they will come out for a couple hundred dollars, and you could see the problem and locate where the problem is. If your pricing is similar to mine, that would be an easy way of seeing the condition of the pipe and have a better idea of what the issue is.
I was appealing to the DIY aspect but yes, that would be good. Dig up as many places as possible to get into it with the camera first, as we bill by the hour.
bam1968
IA
Excavating Contractor
From your pic it looks like tree roots might be the cause of your problem. They will plug a tile in a surprisingly short amount of time.
Tinkerer
usa
One thing I have done with field tile is to dig up with a backhoe, both ways from where there is a blow hole.
Maintain the grade while removing the old tile and drop new tile in as I go.
You will definitely find where the outlet is doing that.
I have found lateral lines doing that and never knew they existed.
Yes as @bam1968 pointed out, tree roots are killers with jointed tile pipe. If it is all put into plastic gasketed or glued pipe, that problem goes away. It is a big job either way.
Beckbenj
Ohio
Thanks for the comments. This leads the discussion in another direction…should the replacement tile be corrugated, dwv, gasketed?
As far as the main line, I’d assume it is solid and the laterals are the perforated?
