RocksnRoses
- Joined
- Jun 14, 2008
- Messages
- 770
- Location
- South Australia
- Occupation
- Owner operater crushing & contracting business
The transmission on our Dresser 540 has suddenly started to run really hot. It has been working fine up until recently, but now in about 45 minutes to an hour of average work, the temperature goes up to about 240 degrees F, where the buzzer starts. When it first got hot, the oil level dropped quite dramatically and I topped it up, but I could not work out where the oil went, because it does not leak that bad. I am wondering if the seal on the torque convertor has let go, filling the fly wheel cavity with oil, because it is very wet around the starter motor and a couple of other spots on the fly wheel housing and I do not think that there should be oil there, but I am not 100% sure. When the machine is operating, there is no sign of any slippage anywhere, it all works quite normally, but just gets hot. We have cleaned the radiator and oil coolers and the engine is running a little under 180 degrees F at the time. I am wondering if some of you fellers that have operated these machines over the years, might have any ideas.
Rn'R.
Rn'R.
