The U joints on the front driveshaft of my 2011 F350 were making noise so I pulled them out to replace. I discovered what is called a Cardan joint between two U joints of the rear knuckle to form a CV joint. I'm thinking I should probably replace this while it's apart, it must be worn as well. I found a video on replacing one on a Dodge that looks identical. I've found a replacement part for earlier F350s but I'm coming up empty on my year. Do any of you have information that would help me?
