JDirt
I know I've seen this somewhere, but can't find it. I have never touched it, but want to make sure the plate on the bottom of the pump head is in the right way.
The way I understand it, one way is normal, then if pump control goes haywire, you remove 4 bolts and turn the plate 180*. That puts pump in limp mode, like 60% so you can move the machine.
The plate has a hex shaped pin that is offset one way. So which is normal, pin toward the motor, or toward the door?
