EX120 Lights
Matty
Sandpoint, Idaho
Hey Folks,
I have an EX120 with 4 mounts on top of the cab that look like they are made for lights... this would be great as up here in the north we get very little sunlight this time of year and the single light on the machine just isn't enough especially when you want to see what is behind you.
I know the system is 24v, but can't find any lights for this thing out there... also, where would these wire into for the console switch or should I just go off the boom light? Any thoughts / ideas would be helpful.
Thanks,
M@
danc
ireland
if you find 12v lights that physically fit go get them, and replace the bulbs with 24v items.
just don't go over the recommended wattage for the lights you choose
don't touch the glass of the bulbs when changing, esp if they are halogen
I'd imagine the boom and toolbox light are on the one circuit,
so I'd run seperate cabling into the cab.
does the existing switch have 2 on postions?,
if so I'd wire it as follows from OFF:
pos 1 boom/toolbox light,
pos 2 ALL lights on
use the switch to run a relay if one isn't there already
kenworth
Central Washington State, USA
Jack of a Few Trades, Master of None
Matty
Sandpoint, Idaho
Gary,
Thanks for the response. I was able to follow the lights link, but not the switch link. Can you give me the item number(s) you were referring to on that site. Couldn't find them hunting around.
Matt
