Excavator Cleaning
Beckbenj
Ohio
Hi All,
I’ve been cleaning up a Kubota KX161-2 purchased a few months back and am curious on the proper way to clean accumulated dirt / grease out of the belly of the machine. I’ve been digging the packed in mud out with a scraper at this point but there are areas that can’t be reached even with that tool.
What’s the appropriate tool to use here and not cause issues with the valve stack, hoses, and few electrical connections that run in this area?
I’ve read about pressure washers or steam systems. I’m hesitant to use a pressure washer in this area for fear of driving water into one of the hydraulic valves.
How many inspection plates on the bottom?
The best we've found is a good de-greaser and plenty of water. Rinse and repeat. Gotta be careful if you use a pressure washer in tight quarters like that.
Beckbenj
Ohio
There seems to be only 1 small plate off to the side (green arrow), so not much in the way of underside access.
Maybe a wide spray nozzle on a pressure washer to limit pressure after spraying with degreaser. I also wonder if one of those foam blasters for a pressure washer would work? Spray the foam, let it sit for a while then rinse off.
That is a very interesting scraper you have.
Beckbenj
Ohio
Thanks for the info.
The scraper is some plastic job from a local auto parts store. Works well when scraping sensitive materials (aluminum, etc.)
masterwelder
NY
Agree with Vetech63.
I use a Hotsy steam pressure washer. 240 degree wet steam melts grease/oil etc. and the water pressure carries it away. You can always stay back from the machine to lessen the impact of the water if you need to. Also changing the nozzle affects pattern of spray and/or pressure.
Turn off or disconnect electrical and avoid spraying directly at connectors. Be careful around stickers also unless you want to remove them too. Make sure to wear safety glasses and face shield. Shield and glasses will fog and get wet making it hard to see but it’s non negotiable, you have to have them along with rubber boots and rubber smock. It’s a dirty job but if you want it as near to day one clean as possible, steam is the only way.
I have steam cleaned a lot with no problems. I like to wash when I can let the machine sit and dry. A windy day helps.
You will not regret owning a steam jenny.
I don’t use degreasers, the wet steam does all the work.
Coaldust
Subarctic Backwoods Trailer Park
Big trucks is what I know. HAZMAT is what I tow.
That Hotsy is probably worth more than the hoe is. I keed, I keed, …
Seriously, has anyone priced a new 1200 series, lately?
