Excavator lift style bedding box
Bls repair
S E Pa
Equipment operator,mechanic
I would prefer a regular stone box you can use it with a small machine to a big machine,as long as you can get the bucket in it your good to go.
Mother Deuce
New England
Need to secure it to the bucket somehow. You have to plan for not only the very professional safety conscious operator who will keep the bucket curled. As well the one that while well intended, won't.
Bls repair
S E Pa
Has limited working area and control compared to a bucket full of stone.
Reggie Schrank
Gillette, Wy
Photo #1. This is a still from a video while in normal use. Keep in mind the operator wasn't trying to see how far he could throw material for the video. You can get material as far or further than a bucket can.
Photo #2. Is the box 100% locked on to the machine? No. It is designed to maintain connection while under normal operation.
Tags
Connecticut
Seems like a good idea on a site where you couldn't get a truck close enough and the equipment you're using is big enough to handle it when it's loaded with stone. I usually just get my 10 wheeler close with a load of stone in it and dig out of the back.
Reggie Schrank
Gillette, Wy
Bls - those are pretty much the standard and what everyone has used for 40+ years.
This style really shines on a replacement mainline job where worksite space is limited. Sidewalk, trees, prestrung pipe, grade stakes, spoil pile, ect.
Bls repair
S E Pa
I done many main line replacement and new installs through woods and first thing you downsize is the hoe so you can by trees and branches
Reggie Schrank
Gillette, Wy
Specs list the hoe size range as 50k lbs - 100k lbs. That Cat 326F is a ~60k lb machine and had no problem with a full box.
How big of machine would you normally use vrs the smaller unit for tight areas?
Bls repair
S E Pa
312 size machines in tight areas
