CD Player upside down and in water
Had a 1994 honda civic, just put $2500 into engine work and new rubber.
I was on my way home from my first gig with the band i was in at the time, had two buddies in the car packed with gear (guitars in the trunk, amps in the back seat) So, we were pumped and i was clippin at a good speed when i decieded i needed to drain the lizard. So with no hesitation i gradually started to slow from 110km/h knowing where a good spot was. I had slowed her down to about 50km/h when i approached the turn-off and started to turn in, at that moment i hit loose gravel from all the transport trucks going from dirt to pavement and it locked her up heading straight for a sign with 3 neatly placed 4-5ft boulders in front. So, I went into action mode cranked the wheel back to the road pulled the E-brake, which swung the tail out, then floored it and slamed the E-break back down, everything was lookin good as i jetted back out to the highway but unfortunatly there had been a washout on the far edge of the road which left the curb and no material below so instead of hopping up on to the road my passenger tire got caught and swung me back toward the ditch. At this point i thought i was in the clear as i figured the worst that could happen was i would just hit the bottom of the ditch and wipe the **** out of my pants and call for a tow... Needless to say i was wrong the car came to a stop and started sliding down the bank to the passanger side,
