Well, I finally had to run an M as the dealerships had no H's available. This first half hour was ugly, by noon not so bad, by the end of the day I can see why guys really like them. Although for an old man like me I would need about 500 hours to really get comfortable.
Biggest problem was steering sensitivity, or I was just centering it every time. I chased those front wheels all over the place, but by the end of the day I was getting a bit smoother. Seems like it was worse trying to go straight while articulated, but that was probably just me.
The visibility is great! I don't know if it is just my imagination, but it seems as if you sit up over the moldboard a touch more than the H's. Rear visibilty is not great, but I am fairly tall and sit with the seat high, so no big deal. The cab is very nice an quiet, so much so that hearing the engine pull was a bit difficult.
In the afternoon I caught myself using the right joystick as if it were a dozer, when i wanted to tilt a bit I would move the joystick sideways. Fortunately is just side shifted a bit and didn't screw the grade up. Too many years running dozer I guess.
One thing that pixxed me off, back when I was running a G I spent at least a half hour just practicing moving the saddle using lift cylinders, side shift, and lateral side shift all at the same time (push two levers on one side and pull two on the other). Now I am going to have to do that again and go through the thought process of figuring out what my hands have to do to make all that happen!
All in all it was a pleasant experience, and I am no longer afraid of them.
