Flowmeter advice
92U 3406
Western Canuckistan
Wrench Bender
Most likely going to need to run a flowmeter on a job next week. Been over a decade since I've last used one so hoping for a little advice. I believe its a Hedland flowmeter.
funwithfuel
Will county Illinois
Mechanic
I've not seen hedland flowmeters offered with a needle valve unless someone plumbed it in afterwards. Be careful as most flowmeters I've seen caution not to exceed 3k psi. They're usually aluminum and plastic
92U 3406
Western Canuckistan
Wrench Bender
The setup I'll be using has the pressure gauge before the needle valve and the needle valve is before the meter. So the meter will only be exposed to the backpressure in the line returning to tank.
Tenwheeler
Georgia
Many years ago I bought one from Northern Tool. Purchased a needle valve from a local hydraulic supply and teed in a pressure gauge. That was an inexpensive way to do not but must use extreme caution. It has no relief.
Coaldust
North of the 60
I noticed there are quit a few YouTube videos available from the hammer manufacturers outlining their process.
