We have tested many types of material.
In -99 we filled a lot of wheels with a rubbercompound.
That is now a PIA, the pressure of the stuff is out and the rims are loose.
But not to loose to get the tires off the rims.
We are using a ripper tooth and a exc to tear the tires apart and get it off.
We are now using a floating stuff called Tyreprotector, that u pump trough the valve pipe.
U take out the valve and attach a hose and pump or blow the stuff inside the wheel.
Covers the tire up to the sides in a hight according to how much u fill inside.
Stops holes up to rebar size 1/4"(6mm).
And it works! I have had tires leaking, pumped it in, turned one round and its air tight.
Realy impressing. If u change tire, pour it into the new wheel and mount it.
Works as long as it aint to long in open air.
Consists of old tire rubber bits and a liquid with antifreeze and a vulcanition agent.(secret resepie)
I am very pleased with it and ad it to nearly everything.
Punctured tires is history by us.
Pay by the volume, volume is dependent of the wheelsize. Big wheels, cost much.
here is the website:
www.tyreprotector.com
