trickortrauma
I have a Ford 555 that runs great, hydraulics work like a champ, but I can't get it to budge either forward or reverse in any gear. The "Component" number is 19-802.
I bought the unit being told there was an issue with a "Valve Body". I went into the valve body that seats on top of the transmission hydraulic pump and replaced the springs and pins. Now the shuttle shift feels like it is more positively engaging forward or reverse and it would turn the wheels in forward but only with the outriggers down and then you could reach down and grab the wheels to stop them from spinning. The unit did not have enough power to move itself.
I hooked a pressure gauge to the testing port and didn't register any pressure at all. I had been told that there was a screen at the bottom of the gearbox that would get blocked up so I hooked an air compressor to the test port and got a good steady volume of air to pass out of the gearbox as the fluid was emptied. Put it all back together again and nothing, still no more wheel spin and still no pressure on the gauge.
I've read other threads where people talk about a wiring issue that leads back from the transmission. I've gone through my backhoe and the service guide and the only wires I can find associated with the transmission are for the neutral safety switch.
I've thought it might be the hydraulic pump but why would I get any wheel movement if that was gone? Someone else suggested clutches but wouldn't they fail independently and you'd have at least movement in one direction?
Any help someone could offer would be greatly appreciated. Thanks in advance.
