Ford 655D Solenoid
Alberta Blue
Alberta,Canada
I ended up buying the backhoe and it has been great. I do have a small issue though. The reverse solenoid works intermittently. I checked with New Holland and found it is discontinued. I may have found one in Louisiana. It is pricey. Can solenoids be rebuilt? The part no is
K3660224151
Thanks for looking
NH575E
North, FL
Retired Machinist
Have you looked on the solenoid itself for a manufacturer name and part number?
Another thought on yours is it could just be a broken wire making and breaking contact. Check the connection and wires and look for rodent damage.
I had to replace the 4WD solenoid coil on my 575E. It was also discontinued. I think it was available as a complete solenoid for $500+.
Took some investigative work but i ended up fixing my issue for less than $20. The manufacturer had my exact plug and play coil for a little over a hundred bucks. The one I bought for less than $20 just had bare wires. All I had to do was splice my connector onto the new coil.
https://www.heavyequipmentforums.com/threads/new-holland-4wd-solenoid-coil.71967/
