HDX
This is the window track used on all these trucks. What will happen is the felt inside the window track wears out and will come loose and gall up
causing the window to bind--acts like a friction and makes it really hard to roll the window up. Another problem is the felt is completely worn out and the window will **** in the tracks. This is when extra force is used and the above pictures show what happens. I had explained awhile back
about using plastic snap ties inserted in the window track when the felt is badly worn and this is how you do it. All you do is cut the head off the snap tie and insert the rest of it into the track. This will tighten the window up and stop it from rattling or binding.
