Hardlyworking
I have a 80's Gehl 3610 not sure exact year but I think 86. I'm trying to change the spindle bearings and seals. I started last fall and after a failed attempt the skid steer died and got shoved to the side. I have one front corner done, by just unbolting the hub, rocking the whole assembly back then I was able to reach in with a bar and flip the chain off. Then onto the back... I tried to do the same thing but I can't get it to rock forward enough to get enough slack on the chain, I seem to remember I may have on one attempt but then couldn't reach into the chain... I assume there has to be a tensioner I can loosen to get some slack to get the chain off the sprocket? There is a bolt between the two tires sitting vertical, I tried loosening that last summer when I broke a link on the drive chain but it didn't seem to do anything.
