Search this forum for Takeuchi relay problems. It is a fairly common issue and resoldering the interlock relay is a low cost repair. Your gehl is made by Takeuchi, and same as a TL130
Edit: try this thread.
Appreciate your reply.
We replaced some hydraulic hoses that leaked as well as track drums.
now the CTL60/TL140 will not move. The engine starts The Right joy stick works and the controls work , but tracks will not move. Hydraulic pressure is good( tested ) To me one ( or more ) safety relays are not working.I
Parts man at Local dealer confirmed that these units have TWO prox switches , one on the safety bar another built into the seat mount plate ( $600). His records showed no one ever bought a new plate but lots of 17119-00062= BE31-107 relays. He said most people just start replacing relays, sell them often.
He could not tell me what relay location was associated with either prox.
The electrical system drawing identifies K (7) as the safety bar switch ( it is a sensor) but also A (3). None indicate where the seat safety is connected.
Do you know which relay I should replace ? Thanks
