MitchellR
Hello, I'm working on a Genie z25/45. When using the basket rotation switch, sometimes the basket would rotate all the way to the right, and I then would not be able to rotate it back to the left at all. Every now and again I would start it and it would almost magically move back to the left if I tried it. Then the next time It wouldn't work again. This is an issue from the basket as well as from the ground controls. I can see the hoses flex with pressure when I work the switch. I figured it was an issue with the counterbalance valves on the rotator at the basket, so I installed new ones. It did not make a difference. Any ideas? Does not seem to be electrical since I'm getting good response from the motor bog and flex of the hoses.
