vapor300 I've given this some more thought and want to look at it a different angle, specifically from a cost vs. production standpoint and what would need to happen to get your money back from making these changes. All these numbers are estimates.
We'll use just installing the push block and hook on one scraper and compare it to one without.
I think it's going to take about 1 ten hour day for two mechanics to install these pieces on each machine,(dozer and scraper) possibly more. With a service truck and crane, etc. That's 20 MH/day for 2 days=40 MH. I don't know what your labor rates are, but I would say $30/hr would cover wages, burden, etc. That's $1200in labor. Add the service truck @$50/hr. Thats's $1000. So we've got $2200 in labor and rent.
I don't know how much the material is gonna cost, but I'll guess that the push block and bail is gonna cost about 5k and the stinger and hook will be 3k. So we've got $6100 to put this on one scraper and $4100 on the dozer. Initial investment of $10,200. Multiply accordingly if you wanted to install it on more than one scraper. Maybe you have these pieces in your yard, I don't know, but I'm gonna assume you have to buy everything.
Let's say you would like to pay for these improvements in one 5 month season.
If your average unit price for dirt is $1, you would have to move 10,200 more yards with the scraper with the push block and bail than the one without to break even. If you run these two scrapers 50 hrs a week for 5 months and average 150 loads a day, the scraper without the push block will move around 270,000 CY of material. (again, at 18 CY/load, use whatever CY/load you want to) This means the scraper with the push block and bail will have to move 280,200 CY to break even. Percentage wise, that's an increase of 3.5%. This percentage will get smaller as the volume goes up...... Keep in mind, this scenario is in a perfect world, with gobs and gobs of dirt to move and your scrapers work all day, 5 days a week for an entire 5 month season.
So every day, the scraper you put this on must have 3.5% more production than the scraper without. If scraper A gets 150 loads, Scraper B must get 155, so on and so forth. Doesn't sound like much and seems very attainable, right? Possibly. Remember though, this 3.5% increase in production is just to get back to EVEN, not to give you a competitive advantage. You'd have to DOUBLE that to make it worth your time, in my opinion. The scraper with the push block and bail doesn't go down the haul road any faster than any other scraper in the spread. If you did this on one scraper out of 12, it would be critical to stay in alignment because what happens if that scraper shows up at an odd time and meets his dozer (one with hook) at the beginning of the cut? He's not (nor should he) wait for another scraper to come in ahead of him so he can get behind it.
This is probably more than you were looking for, and I apologize in advance if that's the case. This is just the way I would look at it if I were weighing it out. Good Luck!
