Steve A
A while back I bought a Cat 943 track loader with a spun rod bearing, I didn't know what the problem was until I got it in the shop but I expected major engine work. Once in the shop I dropped the pan and found spun rod bearing with crank journal damage. I removed engine, had block hot tanked, inspected, re sleaved and new cam bearings installed, Had crank welded up and turned, assembled engine myself, head was checked, and all new valves installed, replaced all 4 fuel injectors, the one thing I did not work on was the injector pump, I simply cleaned and re installed it. On start up day It fired up and ran smooth, no smoke but if I reduced the throttle fast it would just die, if I slowly reduced the throttle to a slow idle it will idle.
I used it to move a couple buckets of dirt and was happy to find everything else seemed to operate nicely just no response from the governor. On advice from EDB at the ACMOC site I tried adjusting the governor damper screw. it made no difference at all, I removed screw, blew air through hole and even removed back cover to inspect and clean, no difference, a few days ago I started machine after sitting for months, it started instantly and ran without smoke, I tried removing damper screw with machine running and 50 psi of oil pressure, only a small dribble of oil flowed out, This I find odd. like I mentioned above I assembled this myself and I am not a professional, I was very careful with all the o rings under the oil cooler and between cooler and pump but fear I missed something, where did I go wrong?
