diamondtguy
The Grizzly report.....Worked all week again so not much time with the truck...Painted (POR 15) the outside of the frame rails and reassembled everything.All the wire harnesses are covered in that black plastic tubing and I actually don't like the stuff and am removing it all.I started on the left front harness..
I also hung the clutch pedal and figured out all the holes.Took some thought as available space was limited.The cummins uses a hyd clutch pedal.The brake and throttle pedal are too close to the floor and I will raise them slightly.
Lots on the go right now....
My little 67 won first place in last Mondays car show....
