Harness Code
Olori Joshua
Abuja, Nigeria
Heavy equipment technician
Thanks for your answer.
Yesterday I was curious about it and I removed a harness code connector from a D6R III and I had the below active code on the transmission ECM, with the Code certain functions could not work. I put it back and the code stays ON until I turn OFF the disconnect switch and turn it ON before it cleared and all functions started working again. It is that important.
650- 2​
Harness Code Unknown​
Olori Joshua
Abuja, Nigeria
Yes,
In a lot of older models removing the Harness Code plug then turn on the key would put the operator monitor into diagnostic mode.
I see newer machines not with harness code but ECM location code.
