Hello gentlemen, Seeking info on Old D6 Cat
Any idea what size Allen wrench it takes to get oil plug out of the engine ? Just enuff room to get my arm under there,found water in the oil so I guess the heads coming off .Weeeeee fun fun fun.Not sure if water pump went up an she run hot or exactly what happened. I havent run the machine 30 minutes just loading an unloading. Pretty sure it was already an issue because oil looked like it was just changed.
bccat
Langley B C
Retired millwright,Heavy Equipment Operator
Just find a bolt that the head fits inside, thread 2 nuts on & weld together, also fits other compartments
Puffie40
Southeastern B.C.
Is it colored with antifreeze? My thought right now is other than a active leak from a cyilinder jug, it could just be some condensation that collected from sitting.
Also, my experience is that the carbon in oil settles and can potentially look clear if the engine sits long enough.
I guess Im saying I would be skeptical in assuming the oil was 'just' changed.
ianoz
australia
Lot of the time Water in oil is a Precombustion chamber rusted through .They screw out of the head .
Manuals , check on Ebay .Try and avoid the reprint ones as the photos usually are not very clear .
