Legdoc
I am in the market for a new or slightly used mini excavator for ranch and construction projects which are numerous and reduce the never ending quest to obtain reliable temp labor. My schedule is sporadic and renting is not an option. I have a Case 580M , CTL with assortment of buckets, hydraulic auger, HD grapple and ag tractors. The list of uses are as follows:
Reduce the need for a shovel. At 60 my back is done.
Trenching to install utilities.
Dig and chamfer 12" wide foundation beams in heavily compacted soils.
Handle and load with a thumb downed trees, brush, and other debris some in uneven ground.
Install culverts.
Demo some old single story structures. Do landscaping work with a 36" tilt bucket.
Drill for posts and pilings.
Possibly dig my own grave! Just kidding, hopefully I'll be around a good 25+ years!
A cab is required due to the heat and Africanized Bees.
I want to stay with Kubota as all my equipment is that other than the 580M. I am considering the U-35 as it is also the largest unit available without going to a DPF which I want no part of. The local dealer is not an option but there are others within 90 miles. The 580 can handle any heavy digging but is simply too large to get in tight areas which are many. Also the ability to swing 360 degrees is a game changer. Your thoughts on this unit and the application is appreciated as there is not much info on it out there. I have the means to move this 4 ton machine easily.
Thank you in advance.
Install culverts.
