Hi, I have searched for hours to find some incite on this issue.
I have a 2014 CAT 259D that intermittently, while in use abruptly stops and applies the park brake. The error code that show on the display are as follows: (these are from the history so they may not all apply to one event)
2474-3 Left Joystick Forward/reverse position sensor voltage above normal
2474-8 Left Joystick Forward/reverse position sensor abnormal frequency pulse with or period
2476-3 Left Joystick Forward/reverse position sensor voltage above normal
1007-3 Joystick mapping switch voltage above normal.
I have to assume that I may just need to buy a new LH joystick from CAT for around $800 but I figured I would check here before I get my wallet out. Any ideas would be great.
I have been reading the forum for some time now, thanks for all the good info !!
