My operators handbook dosent show the swing out jib with the pullout section.I wounder how grove says to extend & retract the pullout?
Muscle...in and out ...grunt and hump.. theirs no where in the manual thats gonna tell ya to hook on to something ...and as far as booming up ..if it gets away its gonna get broke....
after doing it a half dozen times by the book ...i had a few of the more experienced guys give me the heads up ...and go that route ...like anything on a crane you have to pay attention and treat it like your first encounter with a lady friend .. take your time dont get ramming and dont hesitate to get out and look around ...espicially if the ball is getting of the ground and the sag is comming out of the hoist line ....means shes bound up and may need a wiggle or the pin wasnt removed ...big thing is pay attention ..
out is easy for the most part gravity is on your side ...some have roller's others have teflon pads... alot of guys make the mistake of greasing those ...there best left dry and an ocassional light oil applied to the contact points in the belly of the section.....the rollers arnt always metal and are nylon,or teflon ...have to watch they dont get stiff and make a flat spot on them..again light oil or white grease inside the bushing saves a world of frustration.
Now some of the GMK models ...in particular the GMK 6350 ,it has a pull out in its swing away..but its run by a small hydraulic motor coupled to a chain drive...power in and power out .... sweet deal..
Im sticking my neck out either on a fact or a fanatasy ...but i do believe that terex(75T persay) has a lug to attach the becket to retract the pin section ......im almost certaian of that
