On the EX100-3 wiring diagram the EC Motor Relay should have constant 24V power at #1 & 3 contacts of the relay. I have voltage at the 5 amp fuse but nothing at the relay. Is there a switched routing I'm missing or a potential break in the wiring? My EC motor isn't working. Can someone provide me with the diagnostic voltage &/or ohm readings on the motor/sensor/& EC harnesses so I can decide which rabbit trail to run down. If I install a manual cable throttle and abandon the EC motor, is there any feedback problems to the controller that would affect the pump operation?
By the manual the #2 relay is a Pump Control Relay. I can't find any reference to it on the wiring diagram. Did they change this model to direct power to the pump control solenoid valve? Is that #2 relay doing something with the pump or something else?
Thanks for your help.
