1stephen
does anyone know where the wire connector is in the cab tor connect the factory wiring harness for a travel alarm. the machine did not have an alarm on it when i purchased it although it did have the switch on the left arm rest for the alarm. I have purchased the wiring harness that goes from the cab to the switch (which i have also bought) then onto the alarm(again bought). this wiring harness will just plug into the switch and the alarm but i cannot find the right plug-in for the cab connection. the only connector that i can find that is 3-wire has the wrong plug on it and the wires are a different size as well as 2 of the wires are not the same color. any help and maybe some pictures is greatly needed!!!! thanks
