Hitachi EX58mu Isusu 4LE1 fuel leak
ZGrant231
Oregon
My 4LE1 has developed a fuel leak at what isuzu calls the fuel pump. I replaced the o ring in the injector body but still have fuel coming from the steel plate and aluminum body held together buy the 5 point bolts.
5 point bolts are usually a security or safety feature.
Is any one familiar with this type of injector or how to fix this leak?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
That is the injection pump.. its VERY COMMON for them to leak there.. 3 orings..
special socket from Zexel.. [diesel kiki]
That is also the EQUAL fuel delivery setting for each cylinder.. if you mark it in place, you wont have a problem reinstalling it.. There is also a front & a back.. so mark that also.. they can go in backwards..
thepumpguysc
The pump p# is stamped into the base of the pump.. its a partial pump # & has to be decoded inorder to get the correct oring #'s.. I can see it in the 2nd pic but cant make it out..
You can drive a socket over the bolts & just replace then w/ some METRIC cap screws of the same thread & length..
ZGrant231
Oregon
Thanks guys, I'll wash the engine tomorrow to prevent contamination and see if i can get those 5 points lose.
thepumpguysc
Why don't you post the #'s stamped into the pump BEFORE pulling it & get the orings 1ST..
ALOT EASIER to put on new orings & put back together in 1 sitting..
ZGrant231
Oregon
#45050, matched them with my hi temp CAT brand viton O-ring kit.
13.8 ID
18.6 OD
2.4 section
Replaced 5 point with standard metric bolts.
Thanks again thepumpguysc!
ZGrant231
Oregon
Well after destroying numerous sockets, the other three pumps have began to leak.
I've searched high and low for this 5 point, 10mm side to point socket.
"Thepumpguysc" do you know where I can buy this socket? A link would be much appreciated.
jayz
md.
hello thepumpguysc i have a john deere 50zts with the isuzu 4le1 with the same fuel leak as zgrant231. is this something i can attempt? i am a mechanic, but not really great with diesels. my pump# is 61021. any help you could give me is much appreciated.
ZGrant231
Oregon
I don't see why you couldn't tackle it. Just mark with a scribe the exact position before removal. I ended up doing it twice because I used standard rubber O rings instead of Vinton the first time
thepumpguysc
The tool costs over 300.00. And that’s Aftermarket.
I’ve gotten pumps in where the owner just used a chisel to get them out and then went to the hardware store and replaced them.
He went thru all that trouble THEN I ended up with the pump.!!
If your gonna attempt to do it.. U BETTER GET THE RIGHT ORINGS..
jayz
md.
thanks zgrant231 i was wondering if the engine has to be in a certain position to take the pump out, or will it lift out after i remove the fuel line and 4 mounting bolts?
Jacobm
Lehigh Valley, PA
I'm alo about to emplacement these 3 oring could anyone walk me though itim unsure if I just remove the 2 5sides odd bolts to replace 3 orings or must I remove the whole unit meaning all 4 bolts if anyone one could point me in the right direction I'd appreciate it thanx also here my number incase txt easier thanks 267 4465711
ZGrant231
Oregon
Jesus christ man!
Proof read your reply before you post it.
After a few reads, i think I understand what your after.
Mark the injector with a scribe line before removing it (Very important these are timed)
Just remove the injector line, and two bolts that hold the retailer.
There is also an o ring in the injector body that you might as well replace while you have it out even if its not that o ring leaking, 50% of the time it's the outers, the other 50% it's the inner on these. I've done quite a few o ring sets in the field now on these old 4LE1s and I really appreciate the simplicity of them.
