Syleng1
Quick question:
Hitachi EX120-2
My hydraulics are getting slow after warm up - previously I asked questions about swing only but now tracks are slowing and eventually the arm and boom movements are getting choppy after run time.
0-20mins all is well
20-30 mins of time loose swing speed
30-35mins tracks start slowing down
35-50mins the bucket functions start to slow and get choppy. Kinda like very jerky and not smooth. I’m working with pressure gauges per manual and find my pilot pump is working at 1000psi always.
the fluid is getting hot like it’s going around the relief valve kinda like the warm up circuit is not shutting off.
I trace all the electrical connectors from the valve bank back to the PVC. All ohm and voltage check okay. If I connect all the solenoids I loose hydraulics. If I disconnect the solenoid (in manual page w02-11-02a) called the solenoid for parking brake- the hydraulic all function properly. Connect it and the solenoid stays on the “electrically on” position which is hydraulically “off.”
so my long question is- if I can trace my harness from this solenoid electrically back to the harness pvc connector and it is not open or shorted to ground (circuit# 112(-) and circuit#110(+) to fuse #9) does this mean I have a bad PVC keeping the brake for the swing “on” and this is not allowing the computer control the pressure electrically?
I recently ordered the DREX on line and waiting for that to arrive. I see where there is a pilot relief valve and a pressure reducing valve and how to adjust. I’m just worried if the machine is bypassing the valves Due to lack of electrical control the fluid is getting too hot and Causing my issues. Any thoughts?
Hitachi EX120-2
