I described the bleed process in an earlier post.
Ok, so tonight I got the following done:
1) Installed a new fuel filter, and put in 10 gallons of fresh fuel.
2) I primed the system with the hand pump, bled the top of the filter housing of all of its air. Not sure the plunger is working all that great. I can build up some serious pressure when I prime my CAT 3208 in my 225 with the hand plunger, so much so that I can't push the plunger and further. This machine, I hear some kind of relief valve after using the plunger for a bit, never feels like it builds any pressure. Do I need to crack loose the nuts on the injectors and bleed each one individually?
3) I harvested 35 gallons of oil from the Daewoo excavator and put it in the UH122. I was monitoring the sight glass and the last 5 gallon bucket put me to the second red line, I assume the level is supposed to be between the two red lines with the boom and stick fully extended and on the ground, so there may be a bit too much oil.
4) I then checked the bleeder screws on the main pump housings.
When I cracked them loose they both were full to the plug level. So I assume this means I don't have to manually pressurize the air tank before starting, I can start as-is and let it idle to see if the air pump is working via the gage in the cab?
Here is a video of the top pump bleeder port when opened up:
Top Pump Bleed
4) I greased the fitting in the main pump gearbox:
5) I checked oil level of the main pump gearbox, it seemed way over full. But the only plug seemed very low, so not sure I was using the correct level plug:
Maybe HYD oil is leaking into the gear pump housing via a bad seal...
6) I checked both planetary gearboxes, the LH one was almost full to the correct level, the RH one however was very low, about 2.5" below the level plug hole.
7) I put more grease into the LH slack adjuster, I got to a point where the track won't fall off the front idler, but I have now put in 3 tubes of grease. There must be a bad seal as I am not really building up pressure like I can on the RH slack adjuster. I don't see grease oozing out anywhere, but that piston is pretty well hidden in the track frame, so not sure I could see that anywhere.
8) I received the new ignition switch from Amazon. That will be the first thing I try tomorrow.
Previously when I wanted to use my starter trigger to crank the engine over, I had to disconnect the battery relay because I assume the batteries are disconnected until the ignition is turned to the on position? So I should connect that back up when I install the new ignition switch?
I think I am ready to try to start this thing tomorrow.
