etd66ss
OK, I figured that it needed to be threaded down when not manually pumping, been doing that.If what you are calling a canister has the dome nut on the top is a centrifugal oil cleaner and should be cleaned out at every service. The gunk inside has to be scrapped off.
Back to the lift pump, what you have circled is indeed the primer but it's also the lift pump and driven off the injector pump so it's a combination of both. On the inlet side is the famous or infamous screen in the banjo bolt which is also worth checking at this time. In the lift pump there's 2 nylon plungers that get pitted causing a loss of suction. European engines use this same set up. I've put a Denso kit into a Scania truck engine with a Bosh fuel system so I know they'll go the other way. A kit would cost about 20 bucks and about 1|2 an hour of your time.
PS the plunger has to be screwed down when not in use, leaving it lose will cause it to wear out.
What I find annoying with the parts manual I just bought is it does not have parts breakdowns for the HYD pumps or engine parts. I guess I am used to CAT manuals that have EVERY SINGLE PART that is on the machine. So do I have to find separate parts manuals for the Kawasaki pumps and valves, as well as the Isuzu engine?
I see where aftermarket pumps are available:
But I'd rather just find a rebuild kit etc.
