profrooky
I'm not real familiar with that type of vapor system. Is that an adjustable orifice in between the regulator and the carb?
I've seen those before and always assumed it was exactly that, to set maximum fuel flow? Never took one off or messed with it though.
Yep, that's what I find on the typical liquid systems with a vapor convertor, you adjust the power valve at the carb at high RPM/full load. Just wondering if that's the problem profrooky is having. :beatsme
Hey All:
I set both the power valve and the regulator to spec and still acted the same.
Until I get the tank flow control to not stop flow when it increases I can't really know what those adjustments will do.
Stay tuned.
OK, there are some wrong assumptions going on here.
1. The protection ball in the POL adapter will only drop momentarily when opened extremely rapidly.
Hi BV- the POL adapter......is the fitting on the end of the hose the threads into the tank?
If you open the tank valve wide, as you should, with no draw, then it will quickly drop closed and then drop back open again when pressure equalizes which takes a few seconds at most. Then it will stay open unless the draw is extremely excessive, we are talking a 100kw machine loaded down, or more. So the regulating with the hand wheel is actually telling you that you are getting too much fuel, not too little, I believe from my view of this over the internet. Post a video I suppose for better confirmation. You could also try turning in the load block adjustment you have there between the reg and carb but mark it first so you can put it back if this theory is bunk.
I turned this adjustment fully both ways with no effect on the engine
2. The vaporization rate of a propane cylinder is something that happens over a long period of time, not right away. I frequently test large machines off a 5 gallon BBQ bottle and they run fine until it begins to ice up which takes many minutes. Run a cold water hose on the tank and it will run until empty with no problem.
Are you running high pressure propane right into the regulator that is attached to the carb?
Yes the fittings you see going into the regulator are right from the tank hose so I guess that's considered high pressure
If so then you need to run 12" WC propane there, need another regulator at the tank to regulate to "house" pressure.
I originally had a regulator at the tank (2psi) but took it out.
Also, I can't see inside that Maxitrol regulator but usually the spring is removed and those are mounted with the nose pointed downward just before the carb to act as a demand regulator.
I was playing with the setting on this also with no effect. I have specs for it (14mm) and the load block (9.5mm) and have set them back to spec. The nose is straight up on this one and it feels like there is a light spring in it.
Let me see some more pictures of the total fuel system including the tank, and drilling out the flow ball is the right thing to do if you haven't done it already.
What is the model number on the carb? And what is the model number of the whole genset?
But for sure before any more testing you need to get a 11" regulator on the tank. Drilling out the ball won't hurt, but I don't think it is any issue here. But that demand regulator can't handle tank pressure. You might need a bigger hose between the tank regulator and the demand regulator, though. That looked like about a 1/4" hose and 1/2 to 3/4 would be more appropriate. Any old hose will do for testing purposes if you are safe about your connections of course....
