How do I determine if I need new sprockets on my CTL?
jimpad
ky
Blew a track and don't really want to buy a new sprocket too but if i have to I will. How do I know if I need a new sprocket?
DIYDAVE
MD
What loader is it? They don't look very worn, to me, no hooking, or cracking...;)
Ronsii
Western Washington
s/e Heavy equipment operator
I've ran the tracks off a Tak like that before but there was a lot of steel cable showing... ;) could be you have other issues with maybe the tensioner or other rollers??? what kind of dirt were you in or was this just in a flat turn?
jimpad
ky
Not too bad a ground compared to what I'm usually on. Tensioner seems too be fine as it held for couple days after i put track back on. Problem was machine came down on track in the rear and cut through the rubber and cords which then shortly failed after couple days use. All rollers are free. What do ya'll think about changing sprockets with other side? I can feel a little ridge on the drive side of the sprocket.
277
Ohio
Driver
Midwest equipment gave me this gauge when I ordered new tracks. They may sell you one for a couple of bucks. Worth a try.20180826_175745.jpg 20180826_175806.jpg 20180826_175817.jpg
catman13
oregon usa
if you are putting new tracks I would put new sprockets , so they wear together and don't cause extra wear on new tracks
