I always try to keep the can low. When ejecting the material, a low cutting edge will force the material to the outside of the bowl which will help keep the rear tires in the same track as the front(if that makes sence). Here are a couple pics from last week. we had a couple operators(seat fillers) that didnt have any scraper exp. Me and my partner couldnt keep up with repairing the pile so the D6 had to help out a coule times.
TDozer, are you guys working off of rt. 70 in Ocean County? Just asking because I saw a 627 on a lowbed going east on 70 the other day, didn't catch the name on the cab of the truck, wondering if that was yours.
Uhhh or just add one or two wide at the bottom, build your edge up a little to keep an inside lean and build that new lift straight up the side? I guess you've never seen scrapers build out an exsisting slope? All you do is start a bench and then build it up beside the pile. :beatsme
