Update.
I laid tracks across forks, put garden hose on cut and cut them with a sawzall. Success is greatly dependent on setup so you don't get binding of the blade... if you've got it setup correctly you can sawzalll through in 1 minute, if not, you wont get through the cut.
If I had to do it again I'd put my forks 1 foot apart and lay track on forks such that I was cutting through the depth of the track (not the width), and the weight of the tracks would keep the cut open.
Needless to say, you should be on a GFI circuit if using AC sawzall.
