How to keep delayed ooze from causing a mess.
emmett518
USA
I've been told to pump grease until it oozes out of the space between the pin and the bushing.
Two questions.
In some bushings the grease does not ooze out equally from all areas around the pins. It comes out one side. Ideally, I should probably remove the pins and clean them out to insure that grease gets everywhere, but that would be a huge undertaking.
Is this OK?
2. I'm finding that despite me greasing religiously, I'm pumping 10 - 30 pumps, and not seeing grease oozing. But when I come out the next day, there's a huge glob of grease on the machine or on the ground.
Is there a technique for greasing that avoids the delayed notification that you have pumped too much, or is it just the way it is?
Thanks
Just the way it is. I follow up after greasing with some motion, then a wipe if it bothers me. If you cycle the cylinders and then wipe, you get most of it right then.
emmett518
USA
What do you wipe with? Zillions of paper towels or rags, or will one rag do the trick? I'm using up an entire roll of paper towels after every grease job.
The company buys me bags of rags. I'll use a couple after every greasing. they work ever so much better than paper towels.
JLarson
AZ
Rags.
I grease pins till I just see fresh grease or if there's spacers see them move a little. Once you get used to moving around and greasing stuff you get the hang of it and avoid the grease blobs.
By the time the pins and bushings as well the gap between pin eye and tool ears gets wide enough to slop grease the entire mechanism is due for refit and shims. Grease should only be a narrow band film between pin and bushing with a slight left over to sneak out to the side plates. Last 963B I have been using has a 1/8-1/4" slop in pins/bushings and gets a Loud Slap as the Cylinders square up inside the ears with additional 1/4" side travel, can visually see the pin in the gaps where that equates to Inches of flop roll in bucket curl and down roll as enter a materials pile as well when trying to load a truck considerable material being tossed from the bucket on any bump as all of the lift/curl slops up and down.
Sadly they are only new and tight when younger, that goes for a great many aspects.
